Two free quarts of oil
I received my 2 quarts of oil and used them to do an oil change. I have always used Polaris oil and filters on all my machines and have never had a problem with oil burning. But, I very rarely drive aggressively. As soon as I received the offer in the mail I figured that they must have an issue with burning oil. Seems like a way for polaris to save on engine replacements. They don't just give 2 quarts of oil away. Ours is a 25 with the less aggressive clutching.
What type of clutching?
2024 Xpedition clutching allowed higher rpm's. Which made the cab noise high. Polaris offered to install different weights to bring down the revs and cab noise free if you wanted. 2025s came with these weights already installed.
I don't understand the thought that 2 quarts of oil stops a motor from blowing, lol. It's aimed at getting people to keep using their brand of oil.
Complementary 2 quarts of oil to have on hand when you check your oil before each ride, so you can add when needed. So check your oil frequently so you don't run it low and destroy the engine. Much cheaper for polaris than replacing engines under warranty. Then, set your oil consumption standards at a quart of oil every 1000 miles as acceptable, no more expensive engine warranty claims. Just needs to last 6 months. That's why they don't offer a longer warranty.
