GPS Not Acquiring Signal
My dealer called me today. Told me Polaris sent a bulletin to update the software to the May 23 update, then check gps functionality and satellite status. See attached
However, when I went to download the software, there was now a March 2024 update. I installed this one first to see if it would fix the issue, and voila! GPS is now working again.
Hope this helps anyone else with similar issues.
Thank you for this. Had the exact same issue with no GPS signal, incorrect time and date, etc. After reading this, I updated to the March 2024 via a thumb drive and the GPS instantly started working.
Ah just had my GPS go into spinning locating mode... man this is just getting to be a big hassle. Everything found in this website I've had and more. Where can someone get the proper software update??
When I had this problem, Polaris had me go back to May 2023, verify that it was working again, and then reload the newest update. That worked and no problems since. I guess there was an issue with the previous software update before this latest one. Anyway, that's what the dealer said Polaris told him.
Sorry I’m late to the thread but I had this issue on mine as well and have seen it on several other Xpeditions. The fix is really simple, just run the latest update, even if your Ride Command is already on it. It has fixed this particular problem every time.
Thanks! That did the trick :)
