Brakes
vince.clemens
arizona
I’m surprised no one has said anything but the brakes on these things suck. Has anybody come up with a resolution? I see that they make rotor kits, but I have built cars for years and know that a rotor kit doesn’t help you need a big booster to make that happen
There’s been posts complaining about the brakes. 😂
They could definitely use lots of improvement. After nearly 2 years of driving this machine, I’ve pretty much got used to their sponginess. Wouldn’t mind anything that could improve them though.
So I guess what I’m hearing is the slingshot master cylinder is a much better master cylinder and bigger and is a bolt on option. I may try that.
Does replacing the master cylinder affect the factory or extended warranty?
If you are worried about it take it back off before you take it in. Shouldn't take more than a few minutes to swap out. If the problem isn't even brake related they probably won't even notice
Does anyopne know what the difference is between the 15-17 slingshot part 1911776 and the 18-22 part 1914620? They look the same so just wondering.
