Sway Bar install
dpm9917
colorado
So like a dummy I removed my front seat bar I thought I wanted more travel but after a few trips I don’t like the body roll and the instability so I’m trying to put it back in but having issues getting it back in anyone have any advice
Generally one would install it the same way they removed it 🤗
If I recall correctly, the upper control arm needs to be removed to get the saddle bolts in as they come up from the bottom.
Then the easiest way to get the sway bar itself back in is to undo the mounts for the radiator so you can lift it a little. It doesn’t need completely removed, and you don’t need to disconnect any hoses. You may need to remove the front bumper and winch though.
