These are some of the issues I am having with my Xpedition.
*Leaky windshield - Polaris replaced under extended warranty with the same windshield with the same issues.
*NOISY! So loud it gave you a headache! We added sound dampening panels and carpet that helped somewhat.
*Engine break nonexistent-felt like you were tapping the brake every time you go downhill-dealer put in a Gilomen clutch kit/ECU ($700) that helped the issues but also caused the already high noise level to increase because it raised the RPMs so much. We added another Gilomen kit ($200) that lowered the RPMs but neither of these kits helped with the herky-jerky when letting off the gas and coasting to a stop. ANNOYING!
*Put in an aftermarket belt that Gilomen recommended showed some improvement.
*Just got it back from the shop due to a noise in the secondary clutch - they had to replace the bolts that came loose and rubbed a hole in the cover - they could not explain how that could have happened.
*Smells like raw gas if you have the windows down.
Looking for solutions/recommendations.
Just to let you know, I am running mostly on blacktop and gravel roads as well as the off-road trails.
