Steep Descent in the XPEDITION
GlobalMapper3
NW Arkansas
Finally took the new XPEDITION to TexPlex in Hollister, MO for a workout and had a great, and educational time. The XPEDITION handled everything quite well and only freaked out the wife a couple of times. My question to Polaris pros here regards steep descents on loose rock which brought about the wife's discomfort and I found especially challenging. A review of the ride showed some of the downhills were in the neighborhood of -25% gradient and were mostly loose rock. Starting down the engine braking handled things for a while until I felt compelled, by reflex, to find the brake pedal, at which time the engine braking ceased and we were in free wheel with only the brakes to moderate our descent. I know that a slight application of throttle will re-engage the transmission but when you are sliding downhill and the machine is trying to swap ends, it is a difficult choice. I'm coming from a Yamaha RMAX which did not have this issue so it's a learning curve for me. How do you pros out there handle this situation?
Thanks,
Steve
Thanks,
Steve
I've got just south of 10000 miles on my X, anytime I'm on a steep downgrade I'm in low gear and never have I had the engine disengage. Now if you were in high gear then you were in high gear and end of story.
Thanks for the response Dallas. I was in low 4WD and had the throttle in Sport mode. I've noticed just poking around that the engine will disengage with foot off of the throttle at low speeds. Are you saying that this is not by design?
