Oil filter
Jeffs
Highland,Il
Any clues on getting the oil filter off?
Have the rear skid plate off and the wrench. It’s supper tight and can’t seem to get enough torque on it without wrench slipping. This is the first oil change on my machine.
If it gets down to it, I use a pair of Channel Locks. It’ll crinkle the filter in but should do the job.
Just remember, when you put the new filter on, lube the gasket and then hand snug! Don’t use the filter wrench to install or you’ll be back to the same problem next service.
Have had a General and a Ranger before and never had this much of a problem. Yes I always lube the new one and hand tight only. Thanks
I had the same issue. It was very tight and difficult to get at. Mine is the adv and I was able to take off from the top access hole. I have a previous post on here about the wrenches I found to make the job easier. Just did my second oil change and was lot easier than the first time
these two tools make life easy, also use the t handle wrench on my 2022 f150 cause the oil filer is in a bitch of a spot.!!!
Just wanted to say thanks! That T handle wrench is perfect for accessing the oil filter on my ADV5 Northstar!
we bought a filter wrench that fits over the end of the filter & clamps on tight. The location of the oil filter is not in an easy access location as we all know....but the engineers dont change oil on their motors
The dealer told me that the Polaris Oil Filter wrench was recalled because it was too loose on the filter. I heard a new one is available.
JG
Top Reactions
