New XP5 Owner - Peoria, AZ
For mine, I tuned for performance. Which means higher rpm.
The ECU tune doesn’t matter as much if you’re looking to lower rpms. That’s done in the clutch kit.
And for clarity, my current ECU tune is from Gilomen, and the clutch kit is from Aftermarket Assassins.
Awesome. Thanks for feedback
I was offline for couple months due to computer crash. We use the rig for casual trail riding with speeds ranging from 15-25 mph. Because of the high RPM that it is turning in this range (4500-5500), the noise in cab is annoying which is which is why i want to lower the RPM in lower speed range. I had a Bikman two stage clutch kit installed that was recommended by my mechanic but is did nothing for RPM in lower speed range....only over 40mph.
