Design Flaws
I should have said minimize air infiltration instead of eliminate. Sorry about that. These machines are not air tight that's for sure.
I just can't wrap my head around the reason they use a boot style on the shifter for an open cab general, buy then put this sloppy slotted system on a northstar edition xpedition
Has anyone noticed air coming in from around the gear shifter on the northstars? I'm not sure why they don't have a shift boot similar to the general
Yes, I took the shift rubber boot out, placed siless sound deadening pad flat with a hole to go around the shifter, then I put fuzzy weather stripping around the shifter rod hole. This helped keep the cold air & dust out a lot for me.
We've also noticed some air coming in by the door hinges, but it's minor compared to the shifter.
I put 1/2" wide weather stripping around the door frame where the door seal sits. Takes just a smaller amount of force to shut the door, but barely noticeable. This fixed the door leaks and hinge leaks for me.
