Ride Command issues
Kordog
12
7
SE WI
Ride Command question. On my General, the ride command would be at the same volume when I turn it on as when I shut it off. Now on the Xpedition it starts off at low and I need to turn it up every time. Also, when connected to BT, I need to press play every time the machine is started, where on my General, it just played on its own. How does everyone else’s work? Is there a setting that I’m missing? Or is that just a new safety feature?
Mine is the same. You might play with the auto volume control setting for your low volume issue?
Anyone have a problem with the Ride Command buttons going on and off on their Xpedition? Polaris already replaced this whole RC unit once because of it and it's doing it again on the new one.
  • 20240512_182135~2.mp4
    9.7 MB
Mine is doing the same thing! only 3 miles on the unit!
What was the problem?
Never figured it out. I noticed it doesn't do it during the night. Not sure if it's something to do with the light sensor to dim the unit. I have tinted windows and wondering if that what messing with it.
I have tinted windows same problem.
You might try switching it out of automatic day/night mode, if you haven’t already.
have you run a software update on it?
Sounds more like a hardware issue but doesn’t hurt to try. Even if it’s already on the latest update, you can re-run it.
Re: Tinted Windows, certain type's of tint such as Metal with interfere with your phone, if you have Ceramic tint, it will not. Best way to tell the type of tint is what you paid for it, Ceramic is the most expensive. We learned the hard way with our truck and put Ceramic in our North star and have not issues.
