Rattle noise
Just got my '24 back with a new '25 front driveshaft. Shockingly the rattle has stopped, but I'm not feeling very confident on it staying that way.
I have a rattle noise around 5500 rpm. Goes away after 6000. Sounds like heat/exhaust shield. Can’t find anything loose. Any one else having issues. XP 2 seater. Thanks
Finally took it to dealer. Extended warranty. They replaced front driveshaft only. Talked to technician and he said new driveshaft slip yoke has a bushing in it to prevent rattle noise…. So far it’s fine. Currently have it on Jack stands inspecting their work. Also had oil pan gasket repaired. Which required a new pick up tube since they cracked it. Plastic tube from what they said. 1month later we just picked it up. Also had brake pressure switch replaced. Now I can investigate how they did. Just an update. Thanks
Best of luck, but don't get your hopes up. The rattle returned in no time at all on my machine... and I mean within maybe 25 miles! It was nice while it lasted.
