Factory wheels
KMFB
9
U.P.
I see that they still can't run the same size tires front and rear. My question is, are the wheels the same width, offset, etc, front to rear if you wanted to put the same size tires on so you can rotate them? I have always swapped out tires and wheels in the past to beadlocks and the same size tire all the way around so I can rotate them. I don't mind the factory wheel and would probably run them if all four are the same wheel.
I put 33 10.50 15” on all 4. No issues!
It helped with the gearing for sure. I also aired the tires down to about 8psi which is about a 32” tire. I’ve had no issues with power, and I’ve been able to hit 60mph, granted I’m sure not nearly as quick as others could, but compared to my ranger, this thing kills it.
Yes, all (4) wheels are identical. 15" x 7" with identical offset.
They have been amazing. I’m on my 3rd set of tusk tires. This is my first set of 33”. Durable, strong, amazing traction on hard and slick rock terrain. Sand not as great, but I’ve not been stuck yet either.
I do get a very slight rub on the xpedition when descending and or turning sharp only. I have few hundred miles on rig now but can only recall it rubbing 3 times so far- I’ve done Moab trails and all.
Hope this helps.
Anybody have experience with Tusk Terrabite 33x10-15 tires on factory wheels? Good price, great reviews, I want to move up from the 30’s
FYI Terranite tires run small! 2 years ago I bought 32’s to replace the carnivores (30”) on my Rmax XTR and the Terrabites (32”) measured 30.5” at 14psi. Not a big deal as long as you’re Ok with that.
Have you had any rubbing issues whatsoever?
I’ve not had any rubbing. I’ve messed with my different fox shock settings, rode over all kinds of rocky terrain. Coming up on 1000 miles and I can only recall 3 times I’ve rubbed and it was not on common obstacles or trails. Psi is also at 14 on all 4.
Hope this helps.
