I see that they still can't run the same size tires front and rear. My question is, are the wheels the same width, offset, etc, front to rear if you wanted to put the same size tires on so you can rotate them? I have always swapped out tires and wheels in the past to beadlocks and the same size tire all the way around so I can rotate them. I don't mind the factory wheel and would probably run them if all four are the same wheel.
