Dash mounted USB Power Outlet
JGKopp
Lake Havasu City, Arizona
Knocked out this simple bracket for mounting a power outlet for my iPhone so cable doesn’t lay across Ride Command screen. It has 3 quick charging ports with an on/off switch. Hot wired to the Pulse Bar so it has power with key on or off. It’s turned off via power switch. Wire clips passed through existing drain hole without any cutting.
John
Whole lot nicer to install it in the dash if you don't mind the cable running up to your GPS or phone.\. Lots cleaner install. I have them in both my Xpedition and Turbo R
Amazon.com
