System three beadlocks
DallasO
Poplar Montana
System 3 bead locks with Sedona rockabilly’s 32 inch. I also installed the AA clutch pack. With the two of them RPM has reduced around 1000 RPM total. Very happy with it, although it does take almost a mile in sport mode to get to 66 miles an hour. But I rarely need that speed. Most of mine is 50 miles an hour and below.
Did you run same size tires and wheels at all 4 corners? If so, what tire width did you go with?
I just ordered a set of System 3 Beadlocks (Wheel Model: SB7 Black BDLK (4+3) 5-LUG) am getting the System 3 XC450 32" tire. Got the same size tires front and back. Gonna be about 4 inches wider than stock with these wheels.. And had the dealer do the clutch gig.
