Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I went with AA for my clutch. Don't know how much better the noise is, its a little better but nowhere near where it should be !! Your right it is horrible. Alot of people have spent alot of money on sound proofing with EXPENSIVE materials with not much success from what I have gathered. The clutching is a good start, but I don't think your gonna get much better than that. Just my humble opinion !!!Been driving my new Xpedition 2 weeks now. Love everything but the noise! Big fail by Polaris engineers. Anyone tried the Speedwerx clutch? It it better than the Polaris clutch fix?? Buyers remorse may be setting it...........................
Do you have any pictures of where and what insulation you installed?We’ve actually been clutching and tuning for higher rpm, and then doing full insulation. Even with the higher rpm we’re able to drop the noise level 5-7db from stock.
Most of the material I use isn’t particularly expensive and some is super cheap. It was a little time consuming at first but after doing it to 11 5 seat Xpeditions I can do the full insulation job in about 8 hours.
Most of the material used is just polyfil from $4 Walmart pillows. Then a piece of aluminum backed fiberglass to block off the hole under the console, some foil backed foam insulation on the lower outside firewall and the expensive stuff is membrane sound mat on the upper inside firewall.
If I remember to take pictures on this next job, I’ll post them.
I made the post over here…Do you have any pictures of where and what insulation you installed?
Do you know what stock db level is?We’ve actually been clutching and tuning for higher rpm, and then doing full insulation. Even with the higher rpm we’re able to drop the noise level 5-7db from stock.
95db-98db stock. ADVs are slightly louder than XPs.Do you know what stock db level is?
Yes. After doing all the insulation that we do. The best one we’ve had was 87db average at 8300 rpm after insulation.Are you at 90db at 8550rpm/47mph?
If you buy the Duraclutch kit you will have no Buyers remorse.Been driving my new Xpedition 2 weeks now. Love everything but the noise! Big fail by Polaris engineers. Anyone tried the Speedwerx clutch? It it better than the Polaris clutch fix?? Buyers remorse may be setting it...........................
