Roof Front Vibrates on Trailer
Highdesert
17
Southeast NM
Just brought it home few days ago. The front 3 or so inches of the roof was vibrating in the wind while I pulled it home, doesn’t look good 👎🏻 . Trailer is level . Any thoughts on this?
Same here. Don’t love it but haven’t seemed to have had any issues from it either.
I am afraid mine will end up breaking off on our long trips from TX to CO. I think I am going to put a ratchet strap on mine from front to back and see if that helps
I had the same concerns.
I added a 1/8"x 3/4" x 26" long aluminum flat bar pop riveted to the underside of the leading edge to strengthen it.
This has helped quite a bit.
I have trailered my ADV2 from Yuma, AZ to Idaho, Utah and many other locations with no problems .
Here’s what I did, just drilled down through the roof into the sheet metal above the windshield. Made a couple bushings and ran a bolt thru it. Way solid now, just gotta paint bolts and washers.
I am going to add your fix to give more support to my aluminum flat bar install as noted in my post above...
More great ideas and fixes from our DIY members..
