Polaris XP\ADV 5 Rear Doors do not open enough.
Patyacht
77
78
Lake Havasu City, AZ
As everyone knows, for a large person the rear doors do not open enough. I looked at Polaris's design and saw that their door straps are wrapped around the window wires then arrached to the door and door frame. The straps only measured 5 to 5 1/4 inches long. So with some left over 1" straps, my wife got busy and made 2 - 6" straps. After mounting the new strap, I zip tied the old and new straps together. I elected not to remove the old strap because they were wrapped around the wires providing some protection to the wires even though there was some bundling when the doors close. Now the doors open much wider to give more room for loading and passenger access. Let me know your thoughts.
No interference at all. Attached are pictures from each side with rear doors full open using the 6" strap! I probably could have gone longer but nylon stretches so I elected to go conservative.
I found just the strap needed to make this job easy. It was a Jeep door strap on Amazon that has different connection points so you can get the correct length. The listing shows the dimensions from one end, but if you measure from the other end, I found a position that made the strap 6.3" long and it was perfect for opening the doors the right amount.
Search Amazon under:
Adjustable Door Strap for Jeep Door Check Straps for Jeep Wrangler CJ YJ TJ JK JKU JL JLU Heavy Duty Door Limiting Check Strap,Black(Pack of 2)​
Made by ROMASO
Made by ROMASO
Appreciate this! Just ordered them for my unit 👍🏻
Did my rear doors yesterday, simple, replace strap with longer one, doors open much wider now, ordered off amazon, strap number in pics.
Made by ROMASO
I used those or similar but the door bracket won't fit through any of the connection points besides the first one. . I had to use cable ties but still works fine.
That is outstanding ! Great job by your wife. If you were my neighbor I would be stopping by with a case of beer for you and a dozen roses for your wife and ask her do mine!
