johndeerefarmer
Today I insulated the coolant lines from the front to the rear. What I did was take some Thermotec and stick it to some Siless sound deadening foam (sticky side to sticky side). I installed one piece on top of the coolant lines with the shiny side towards the lines to hopefully keep the heat away from the cab. I then installed lower pieces below the lines and tied them in place with cable ties. As was mentioned in another post you can't use foam pipe wrap on these like I did my Turbo R so this was what I came up with. We will try this and if still not good enough I will remove the tunnel and use Thermotec on the sides of it. First pix is the Siless sound deadening foam stuck to the Thermotec
