Ignition problem
Norton
jetpwrd69
Have a 2025 xpedition. Turn key to start and only ride command screen comes up. Middle screen between gauges does not do anything. Rpm reads between 2 and 3 and mph reads 30. All sounds when turn key sound but won't turn over. Blue console light is barely in all the time. Checked battery and its full power. On ride command do habe a steering wheel with and exclamation point at the top. Any help would be appreciated. Thanks
Sounds like there is a issue with the electric power steering.
On the ride command, tap the star at the top center, then all settings. Go to vehicle, then diagnostics. It might have diag codes.
Sounds like a possible ECU issue but can’t say without being able to try things.
