Hi from Eastern Montana.
DallasO
26
43
Poplar Montana
I believe I bought the first XP5 delivered in Montana. So far so good. I just returned from Moab.
I did install the AA clutch pack to reduce the RPMs some before we went to Moab. I am very happy with that modification. It still will reach the speed limiter in 1/4 mile in sport mode, so no loss of top end. I still might try 32" tires. I have the Polaris rock sliders and they did get bumped a couple of times the Poison Spider climb.
Moab is the perfect way to break in a new Xpedition! It sounds like the AA clutch pack didn't affect the low-speed rock crawling any?
I have wanted to go play in Moab. It is so great to see a different place to to take an X to. And maybe goto in the future. Any other action pics.
Just installed Sedona rock a billy 32 inch tires and system 3 bead lock wheels. At 60 miles an hour on the speedometer, (which does not change no matter what tire you put on), the GPS was showing me traveling at 64 miles an hour. So that should help For cruising in the 30 to 40 mile range with noise and Economy
View attachment 1342Just installed Sedona rock a billy 32 inch tires and system 3 bead lock wheels. At 60 miles an hour on the speedometer, (which does not change no matter what tire you put on), the GPS was showing me traveling at 64 miles an hour. So that should help For cruising in the 30 to 40 mile range with noise and Economy
I am looking at these, the sedona trail saw and the Sedona Ridge saw. MOAB is my goal. I am also trying to get more miles out of them but I like the low psi. Have you done any rock climbing since you installed these? I know it has been about a week, but figured you might want to do something with them as a test run. I am looking at System 3 3b-7's. Wanted to do 5+5 off-set. What are your thoughts? Trying to get a bit wider stance without breaking the bank.
