Hello from the Midwest!
Smokeybear262
Kansas City
Finally picked up my 2025 Xpedition XP5 Northstar yesterday. Found out last night in a heavy rain that I had some water leaking in at all 4 upper corners of the cab. I will get that addressed. What an awesome machine. Look forward to putting it to work on the farm and some trail riding!
On the leaks, the roof panels never fit like they should. About the only way to seal them up is to disassemble them and line the lower lips with weatherstripping.
The windshield has a tendency to leak at the corners as well. For the upper portion there may be some adjustment available in the hinges. You can use a small Allen wrench to loosen the set screw, then a large one to roll the cam sleeve until it’s as close to the sill as it’ll go. The lower portion typically has a factory problem. The curve of the windshield doesn’t match the curve of the dash. There is a little adjustment in the windshield latch pedestal, but you don’t want it too tight where it might break the handle.
I will look into that! Thank you!
I love that spec! Welcome to the forum!
