I have a 2024 Xpedition NorthStar and was out on a ride and had it die on us. It was running just fine but then the check engine light came on and it made a weird noise (sounded like a heat shield came lose or a chain rattling) and smelt like the belt went out and then quit running. This whole chain of events was about 10 seconds long.
We pulled the cover for the belt and it was totally fine but the engine was seized. Luckily it was right by the truck so we got it on the trailer and brought it home.
The code it gave on the Ride Command screen is the “Driver Solenoid Circuit Error.” This code has sense gone away and there are no check engine lights or codes on anymore.
Just drained the oil and no signs of metal in it and it starts up just fine and doesn’t blow any smoke. When you rev it up it makes a knocking/rattling noise. There is still a burnt rubber smell when you rev the engine but isn’t blowing smoke out of the exhaust.
Has anyone had a similar thing happen or any recommendations? Unfortunately it’s out of warranty so looking for some possible options before spending the money to have Polaris dig into it.
