RSS1977
Hello folks....just joined after reading several things I was interested in on this forum. I'm an XP5 owner and would like to share an option I found for storage. As we know...storage is a huge disappointment in these machines. After searching hours and hours for a bed toolbox (the factory option is too wide and doesn't leave room for coolers and such), I found that Tractor Supply has UTV boxes for $179. They are set up to use with a Polaris Ranger when you add the round pegs on the pre-drilled holes. I found that those holes line up perfect with the Rhino Rack system. You need to use a couple 5/16" x 2 1/2" flange head bolts, 5/16" rubber washer (this help hold the bolt head in the rail still while tightening the knobs down on top), a 3/8 stainless washer (need 3/8 to stay within the rail) and 5/16 fender washers to put on before the knob. Put the bolts on as pictured and then line up the 2 outer holes on the box with the bolts sticking up. Put the fender washers on the top followed by the 5/16" knobs (or nut, if you prefer. Knobs make it easy fro quick removal). On the bottom, use the smaller bumpers supplied with the boxes with a 6mm x 1/2" stainless flat head bolt. This levels the boxes out nice. 2 of these on an XP make an excellent set of coolers/tool/snack boxes. Link below for the knobs on Amazon.
POWERTEC QNB3003-P2 4-Point Thru Knobs - 5/16"-18 Thru Hole Insert, 10 PK Amazon.com
