Xpedition rear chase light
AtomikUTV
Polaris Xpedition Rear Chase Light are now available.
Includes two Amber LED dust lights and Red running/brake lights. What makes this light unique, is the ability to control the ON/OFF function of the center reverse/cargo WHITE LED lights with the included three-position rocker switch.
36″ rear light bar includes RED LED running/brake lights. Blinker capable with any blinker kit.
Polaris Xpedition Plug & Play compatible pigtail included!
100% COMPLETELY PLUG-N-PLAY
for easy installation; includes high-quality GM STYLE Deutsche connectors that plug directly into our compatible pigtail. No more wire cutting or crimping required!
Polaris Xpedition LED Chase Light – San Felipe (Amber/White) RLB Motorsports
FEATURES:
  • RUNNING/BRAKE LED LIGHTS: RED LED, Blinker capable with any blinker kit (sold separate)
  • LED: Dual Function AMBER/WHITE
  • ROCKER SWITCH: Three position Multi-Function Rocker Switch; 1) AMBER OFF, 2) AMBER ON, and 3) MOMENTARY – Quick press- change AMBER strobe pattern, Long press (2 second hold) – turns WHITE utility LED ON/OFF. BESEEN™LED illuminated Rocker Switch fits all factory installed rocker slots, for both UTV and automotive.
  • LED STROBE LIGHT COMBINATIONS: 7 pattern combos; 1 SOLID AMBER, and 6 different AMBER strobe pattern combinations
  • DUAL VARIABLE TRAC-MOUNTING-SYSTEM: 2 mounting slots run the full-length of light bar; 1 vertical (back side of housing) 1 horizontal (bottom of housing)
  • PLUG & PLAY: Polaris Xpedition Plug & Play compatible pigtail included for easy installation.
  • BUILT-IN OVERVOLTAGE PROTECTION
SPECS:
  • LED COLOR: RED: 620-360NM AMBER: 585-595NM WHITE: 6500-7000K
  • LED SOURSE: Epistar 1w LED
  • LED LIFE: 50,000 hour life expectancy
  • LENS: Hard Impact Resistant Polycarbonate
  • HOUSING: Powder coated Aircraft Grade Aluminum
  • IP Degree: IP67 Fully Waterproof Housing
  • WIRING: Sealed GM Style Deutsch waterproof connectors
  • HARDWARE: Stainless steel, mounting bolts included
  • Universal for all12V power source systems
Full Power Consumption: Dimensions:
36”: 36 Watt 36″L x 1.750″H x 2.125″D
