XP 5 Steering
S P Bar
52
29
Ontario
My XP5 pulls to the right all the time. So much so that I have to hold the wheel off center to compensate.
I’ve checked many variables, such as tire pressure and bearings with no relief.
Dealer changed entire steering system including tie rods and it still pulls. If I let go of the wheel while going down the road it will pull right to the ditch. Driving on the wrong side to see if it is the crown in the road and it will pull up over the crown and to the right.
It’s baffling. Any ideas or input.
I did some alignment work on mine and got it pretty good but it pulled some before I did that. Put a turn or two in your front tie rods to push the front of the front tires to the left and see if it makes a difference.
