Has anyone tried to move the switch to a position right below the ride command ? In the lower position I bump it on while moving things in the tray area. Was just wondering if the factory wire harness is long enough to do this.
Buscar under the hood has constant power and accessory power.It is long enough. I had it apart to add the momentary switch, but I'm having trouble figuring out what wire to tap into.
