tires
johndeerefarmer
Texas
After installing the SATV long travel kit and Schmidty Racing Suspension springs and high volume nitrogen caps I wanted larger tires. I was running 32" Terrabites which measured about 31.5" on the machine @15psi.
I was a little worried that 35's wouldn't fit so I went with 34" Terrabites. They measure 33"@ 15psi.
I was also trying to narrow the XP5 some so I bought Pro Armor beadlocks with the stock 61.85mm offset.
Hard to get accurate measurements but I am sitting at around 73" in the front and 75" in the rear. I had hoped to narrow it by 2" over the 5+2 that I was running but looks more like 1" or so.
My trailer is 77" wide and I was trying to avoid buying another trailer. I think I am ok. If needed I can air the rear up a few more lbs to get the bulge out of the tires
Top Reactions
