mike
Had issue with not starting. Checked other threads and found the problem was the brake pressure switch. Did as others recommend and jumped the wiring at the switch and started fine. Now I keep a jumper wire with me all the time. Took to dealor under extended warranty and got repaired and also had it flashed per previous thread on cold weather starting. They said three modules had to be updated, Power steering module, Engine module, and cluster module. It does seem less noise and rpm seems lower. Had the clutch kit installed already. RPM at 30 was 4800 and at 40 was 5200. Steering seemed tighter also, less wondering on roads. Thanks to all the ones that reply to the threads with information. Very appreciated. Thanks
