Install | Light Bar | Chase Light | Whip Light | Wiring
f150harley
77
37
Utah
Having difficulty removing fuse box covers after removing center tray in console. I have released/removed the yellow clips on each end. Thanks in advance for your advice.
Solved... There are four additional black tabs at the bottom / ends of the cover that need to pressed toward center to release the cover. Polaris design included a double/two plastic release clip architecture to insure the cover / lid stays in place. Placement of the fuse box in this area makes it difficult for the casual observer and/or the mechanically challenged to see the securing mechanism for this type of fastener implementation that is intuitively obvious for many. ha
fyi: 40 amp fuse for constant power on Pulse Bar is located under hood/front cover adjacent to pulse bar. 10 amp fuse for pulse bar key ignition (labeled ACCY PWR 10 AMP) is located in center console area . Lift console tray to gain access to electrical / fuse/ relay components. keyword search: Pulse Bar, fuse, relay, key ignition, constant power, electrical, ground, pig tail, led, light bar, whip light, chase light
WD Turn signal video wiring. Front dash disassembly. Wire routing. ryco, street legal, turn signals,
