Heads up new Xpedition owners
tdeperte
116
138
Arizona
The photo shows the wires going into the front differential. They are right above the moving axle on the driver's side. I used a ziplock fastener right at the factory wire hold down to keep the wires off the axle. The pic is after I tied the wires up.
In this photo you can see an AC hose rubbing on the steering motor housing. This is on the passenger side. I put some ribbed wire loom over the hose to protect it from rubbing through.
Another thing to watch is the large coolant hose running along the right hand side of the motor. It’s unsupported and unsecured from where it hooks into the motor to where it goes into the tunnel. There multiple rub points that could cause major issues if left as is.
It’s the same on my Brother’s XP 5 Ultimate.
