GD Momentum 350G or similar
johndeerefarmer
Texas
Looking at a Grand Design 350G Momentum toy hauler. Anybody using one to haul a XP5? Should fit length wise.
Ramp door is rated at 3000 lbs. I am gonna guess mine with Long travel, beadlocks and larger tires weighs over that.
Wonder if I could or should lay a plank on the ramps where I drive up to help distribute the load?
Or if you have a different brand TH, what do you have?
I found with my toy hauler the front and back tires are really never on the ramp at the same time which makes the load on the ramp less. About the time the back tires are starting up the ramp the front tires are crossing over into the garage
