Front drive shaft...?
B B
Playing in the mud
Anyone have any info on the front drive shaft fix for 2024's? Anyone get it replaced? Was told today Polaris shortened the front driveshaft and added a boot. Was this already discussed and I missed it?
The ‘25 driveshaft is the same dimensions, just with the boot added on the slip joint. And they still haven’t fixed the tolerance issue.
The Sandcraft driveshaft, while expensive, is a very good upgrade. It lessens the shaft angles, has fully grease-able u-joints and carrier bearing, and it’s much stronger with excellent tolerances.
