Dale's Snake Pit1
Does anyone know where I can find videos of belt inspection/replacement on the 2025 ADV 5 Northstar? Thanks.
The only difference between the ADV and XP is being able to see everything a little better with the bed up. Everything is still unbolted and bolted back together from the side under the bed frame.I did find this one, but mine does not have the dump bed. In this video it shows really good access to the bolts because they have the dump bed up. It seems like it would be different without having the dump bed to get to everything.
Thanks, really appreciate it.The only difference between the ADV and XP is being able to see everything a little better with the bed up. Everything is still unbolted and bolted back together from the side under the bed frame.
I have found that jacking the rear of the machine up until the tires are off the ground makes everything easier to access on both models.
