I've been hearing a rattle noise at about 5500 rpm on my ADV2 Northstar. Turns out it's the drive shaft to the front differential. The dealer pulled the shaft and greased it which helped some. They also observed the shaft was rubbing above the carrier bearing due to some oscillation. They installed a rubber pad in this area and made some adjustments and now the noise is gone.
